Need gasket for thermostat housing(G262)
Hank L
01-24-2005 22:04:48
Anyone know where I can find a thermostat housing gasket for a G 262 without buying a complete set. Thanks for your time.
Gatz
01-25-2005 12:05:10
 Re: Need gasket for thermostat housing(G262) in reply to Hank L, 01-24-2005 22:04:48
Hank,
I used an overhaul gasket set for a D262, and I know there are some gaskets left over.
If you can tell me the dimensions for the distance between bolt holes, the inside diameter and the outside diameter, I'll see if one matches.
Also, have you tried NAPA or an automotive parts store? Often the thermostat gaskets are universal sizes.
If you go there and they don't have what you need, you could buy some gasketr material and maek your own.
