installing loader on WD45
rwh
01-24-2005 06:55:25
I am thinking of mounting a loader on my WD45. will the hydraulic pump on the tractor run a loader or will I need a seperate pto driven pump There is a bung on the left side of the hydraulic pump on there now. can I install a line off that hydraulic pump and run the loader from it?
Thank You Rick
JMS/MN
01-24-2005 08:47:32
 Re: installing loader on WD45 in reply to rwh, 01-24-2005 06:55:25
Either of your plans will work. You mention a bung on top of the pump- you should currently have two ports with hoses, one to each lift arm cylinder, and the third port will operate a loader with a trip bucket. When using that port, the lift arms will raise first, and normally stay up while using the loader. You'll need a loader with high pressure cylinders since the internal tractor pump develops about 3200psi.
