wd45
zachh
01-23-2005 16:20:01
I bought an old wd45 gas.Some wd45s i have seen have a key switch ignition in the bottom. Did they originally come out with a key? If so mine dosent and i would like to put one back in it. Is there anywhere i can get a new one?
Steve in N.J.
01-24-2005 15:01:30
 Re: wd45 in reply to zachh, 01-23-2005 16:20:01
Zac,
We have the replacement key switches in stock for the WD's with Distributor Ignition. Might even have a nice used Ammeter panel for a 45 with the hole in the bottom for the key switch to. Drop us a line if interested....
Steve/B&B Custom Circuits
zachh
01-24-2005 16:00:39
 Re: wd45 in reply to Steve in N.J., 01-24-2005 15:01:30
are they just like the originals?
JMS/MN
01-23-2005 18:08:31
WD tractors had a simple on-off pull switch. WD45 had the key switch on the lower side of the pressed steel box that hooked onto the battery box. Check with an AGCO dealer for a replacement.
gene (Missouri)
01-23-2005 17:41:27
The switch is simply an on/off switch to control the ignition. You should be able to pick one up at the local tractor supply store or auto parts store.
wdtom
01-23-2005 17:01:34
WDs and 45s had a key switch on the little panel on the back of the battery box, along with the normal/high charge switch, and traction booster gauge. Have you tried AGCO?
zachh
01-24-2005 07:12:10
 Re: wd45 in reply to wdtom, 01-23-2005 17:01:34
No but i will try there
