D17 throttle linkage
Joe B
01-22-2005 05:03:43
I recently replaced the govoner gear and weights on my D17 and adjusted the linkage accoding to the manual.My problem now is the throttle is wide open when the lever is moved less than half of the normal travel range.It will return to idle fine but something is not right.Any suggestions??Thanks in advance
joe b
02-11-2005 04:44:38
 Re: D17 throttle linkage in reply to Joe B, 01-22-2005 05:03:43
I double checked all the linkage and still cant find the problem.Any ideas would be appreciated cause im at a loss.Thanks
waynesville
01-25-2005 18:34:14
Are you sure you don't have the choke and govener rods switched.I've seen it done before.
