Air cleaner to carb hose
Jim's57WD45(TX)
01-22-2005 03:15:52
I recently got a WD45 and need to replace the hose from the air cleaner to the carb. When looking at the air cleaner end of the hose, there is a hose inside of a hose, apparently to make the hose fit the outlet nozzle of the air cleaner. Anyone know what is supposed to be here? Neither one of the hose ends was on tight and neither one seemed to fit right.
BFreije
01-24-2005 06:58:29
 Re: Air cleaner to carb hose in reply to Jim's57WD45(TX), 01-22-2005 03:15:52
If it was me I would get a little larger diameter hose than I needed and get two hose clamps that fit my hose and tighted them down till snug on air cleaner and carb.
Brad Sw Ia.
01-22-2005 23:45:58
Are you sure the air cleaner is a 45 assembly, not a WD? The carb also could be a WD. The carb and air cleaner assembly hose sizes are different between the WD and the WD45. Both original hoses are preformed and available from AGCO. The WD45 hose is same part number that is used on D15. If you have assemblies 'mixed' up, you need a hose with two "different end diameters. AGCO doesn't carry that stuff! Good luck, Brad Sw Ia.
CH (upstate NY)
01-22-2005 17:48:03
Make sure you use fuel resistant hose, very expensive. I couldn't believe the price when I got some from my NAPA dealer. I've done enough business with them that they charged me for 4 inches.
jayw
01-22-2005 05:53:41
Sound like some farmer just didnt have the right Hose and just rigged it up too get by and never changed it out I cant see a issue with it just measure opening and parts house will cut you another piece.
