AC B Knocking
Steve Clark
01-21-2005 06:46:45
I believe my AC B is a 1939 model. It has been great for the last 15 years of mowing. Last year it started to develop a knocking noise. After a few discussions I have been convinced it may be a main bearing going or gone bad. I am about ready to drop the pan and inspect the bearings. Any other suggestions on the knocking noise?
Dick L
01-21-2005 08:06:02
 Re: AC B Knocking in reply to Steve Clark, 01-21-2005 06:46:45
You might be correct but most of the time when these little engines start to knock it will be a rod bearing.
Steve Clark
01-21-2005 08:27:19
 Re: AC B Knocking in reply to Dick L, 01-21-2005 08:06:02
Thanks, I ment the rod bearing not main. Do you know if it can be inspected by dropping the pan
Dick L
01-21-2005 09:02:30
 Re: AC B Knocking in reply to Steve Clark, 01-21-2005 08:27:19
Yes you can. You will have to loosen up the front axle plate on the front of the engine to let front of pan down. Not a bunch, I think you need only a 1/4" or maybe a little more. The big nut under the bellhousing will need to be loosened the same amount to allow the plate to move. I put a jack under the bellhousing and lift just enough to slide/pry it forward.
Steve Clark
01-21-2005 09:33:54
 Re: AC B Knocking in reply to Dick L, 01-21-2005 09:02:30
thanks, I appreciate the help.
Brad Sw Ia.
01-24-2005 08:20:06
 Re: AC B Knocking in reply to Steve Clark, 01-21-2005 09:33:54
Steve, does the 'knock' kind of go away, when you speed it up? You might check the front pulley, they sometimes will get loose, causes a 'knock' when it idles but goes away when you speed it up. You might check that first, lots easier to fix and cheaper!! Brad Sw Ia.
