WC timing marks
Sheila Cole
01-17-2005 14:31:31
Does anyone have a picture of WC timing marks they could email me. Tryng to install a magneto on WC.
Joe M (GA)
01-17-2005 15:30:58
 Re: WC timing marks in reply to Sheila Cole, 01-17-2005 14:31:31
Sheila, check your e-mail for pictures
gene (Missouri)
01-17-2005 15:18:29
Shiela. Pull the inspection plate from the bottom of the bell housing. Crank the engine over by hand until the bolt holding the pulley to the front of the crankshaft is at the 10:30 o'clock position.
On your back under the tractor, shine a light at the back of the flywheel. There should be a line and an "F" on the back of the flywheel. You may need to sandpaper the flywheel to see the mark. If the mark is not there rotate the engine a bit and check again.
A lot of times someone has touched up the timing mark with white paint.
The I&T (AC11) shop manual for Allis Chalmers has a sketch of the timing marks. You might check your local library refrence section and the librarian. They may have or can borrow tractor manuals.
