AC-185 Hydraulic Problem
JoeBTx
01-17-2005 08:53:03
I have a loader on my AC-185. When I stop the bucket (valve from forward to neutral) about half way up, the bucket slowly drops about 6-12 inches and then holds. Fluid is OK no air in lines??? (bucket doesn't jump) 3 point doesn't drop Any ideas before I pull the valve assembly ??? Thanks, Joe
Jerry from East Iowa
01-17-2005 11:08:35
 Re: AC-185 Hydraulic Problem in reply to JoeBTx, 01-17-2005 08:53:03
Hi,
If I was to guess, I would say the problem, more than likely,is with your loader boom cylinder, not your valve. If the bore inside the cyl. is scored they can act that way, or if the seals inside are wore it might take a little oil going buy before they swell against the bore of the cyl.
I have seen this alot over the years. If you have any questions or need advise or parts let me know at [email protected] or call me.
Thanks,
:) Jerry
Jerry's Tractor Repair
563-552-1615 or 563-590-1973
