WC timing inspection hole
WC Dave
01-15-2005 15:24:17
I was just reading the post about timing the magneto to the WC engine and was wondering where this inspection whole is in the clutch housing, I always look but all I see is a Piece of sheetmetal held on by 6 bolts that you can remove, but this can't possibly be the inspection whole can it?
gene (Missouri)
01-15-2005 18:15:33
 Re: WC timing inspection hole in reply to WC Dave, 01-15-2005 15:24:17
Yup that's the inspection hole. There are where two different inspection plates/holes. One was just the flat plate and the second was the flat plate with a second smaller hole with a sliding cover.
If you have the first style, you remove the entire plate. Line up the timing mark (F) with the center of the front center bolt hole.
