WD serial no. More WD questions.
Dave
05-29-1998 20:12:04
I have a 1952 WD by the serial no. It appears to have had an extensive restoration about ten years ago and then sat in a field. My question concerns the engine. The paint condition is much better than the rest of the tractor, indicating that it was changed. It also has a powercrater decal and a block serial of U3019-31. I am wondering if the previous owner upgraded to a WD45 engine or added paint and a decal? Is there any easy way to tell without measuring the stroke? Appreciate all responses.
Dave
Dan D.
05-31-1998 18:54:37
 Re: WD serial no. More WD questions. in reply to Dave, 05-29-1998 20:12:04
: I have a 1952 WD by the serial no. It appears to have had an extensive restoration about ten years ago and then sat in a field. My question concerns the engine. The paint condition is much better than the rest of the tractor, indicating that it was changed. It also has a powercrater decal and a block serial of U3019-31. I am wondering if the previous owner upgraded to a WD45 engine or added paint and a decal? Is there any easy way to tell without measuring the stroke? Appreciate all responses.
: Dave
Check the engine serial number which is stamped on the side of the engine block behind the carburator. A WD engine will begin with W-####, while a WD-45 engine will be 45-####.
mm
05-31-1998 17:02:30
The WD-45 cylinder head is much thicker up and down than the WD head. The name of the stock WD cylinder head is W-201. Naturally the 201 mean cubic inch. Don't ask me what the W means. The name of the WD-45 engine is W-226. My guestimate of the head thickness approximately 3 inches for the WD head and 4 for the WD-45. As far as measuring the stroke. You can roll the engine over to TDC and stick a wire down a spark plug hole and get a rough idea of the stoke. This would not be the first wd to get the power crate sticker mistakenly.
: Dave
Dave
05-31-1998 19:35:13
 Re: Re: WD serial no. More WD questions. in reply to mm, 05-31-1998 17:02:30
Thanks, really appreciate the help very much.
: The WD-45 cylinder head is much thicker up and down than the WD head. The name of the stock WD cylinder head is W-201. Naturally the 201 mean cubic inch. Don't ask me what the W means. The name of the WD-45 engine is W-226. My guestimate of the head thickness approximately 3 inches for the WD head and 4 for the WD-45.
: As far as measuring the stroke. You can roll the engine over to TDC and stick a wire down a spark plug hole and get a rough idea of the stoke.
: This would not be the first wd to get the power crate sticker mistakenly.
: : I have a 1952 WD by the serial no. It appears to have had an extensive restoration about ten years ago and then sat in a field. My question concerns the engine. The paint condition is much better than the rest of the tractor, indicating that it was changed. It also has a powercrater decal and a block serial of U3019-31. I am wondering if the previous owner upgraded to a WD45 engine or added paint and a decal? Is there any easy way to tell without measuring the stroke? Appreciate all responses.
: : Dave
