7040 powershift transmission
Jurgil
01-14-2005 18:04:11
In high range, under load tractor stops momentium, in 4th, 5th and 6th gear. If I down shift it will continue moving. When this happens engine RPM"s do not change. Noticed oil dripping from fly-wheel/torque convertor hole. What maybe the problem? (a seal)
Jerry from east Iowa
01-16-2005 03:05:34
 Re: 7040 powershift transmission in reply to Jurgil, 01-14-2005 18:04:11
Hi I think gcasper is right on the money with his guess. One thing you need to remember is,I usually replace the belvil washer on the limiter because heat tends to weaken them. If you have any questions feel free to call or e-mail me at [email protected] I can also help with parts sales. Thanks :) Jerry Jerry's Tractor Repair Holy Cross , Iowa 563-552-1615 or 563-590-1973
gcasper
01-14-2005 20:25:43
Does the pto slow done as well when the tractor loses momentium? If so it probably is the torque limiter clutch disk on the flywheel. This disk acts as a coupler between the engine and transmission . They wear out on all the 7000 series tractors eventually and start slipping and is noticable in the high gears first. If you hold the brake pedals down in a high gear the wheels and pto probably will stop turning. Tractor needs to be split to replace this disk and front input shaft seal needs to be repalced as well when in there.
