TOP LINK LENGTH 3 PT
Terry Neudorf
01-14-2005 07:32:25
I have a D14 with a 3 pt hitch. The adjustable top arm that goes from my rear blade to the mount under the seat is not the original. I have mine adjusted to the shortest length but it is still too long judging by the blade angle. How long should this arm be?
Thanks
John (MO)
01-14-2005 15:01:09
 Re: TOP LINK LENGTH 3 PT in reply to Terry Neudorf, 01-14-2005 07:32:25
Those SAE specs only really apply when things are factory original. 3 point hitch was not factory original on a D-14, so it"s hard to say just how much longer or shorter your lift arms are than SAE standard or where your top link bracket sets from what is SAE standard. You are just going to have to unhook your top link, lower your blade and get it setting where you want it when it"s at ground level and then measure and see what length your top link needs to be. Then find one or make one that has some adjustment both ways from what you need. Now, don"t assume that it"s going to raise the way you want it to just because you have it setting on the ground the way you want it. Most AC 3 point conversions do not have SAE standard spacing between top link brackets and lift arms so the lift and tilt will not be the same as if everything met the SAE standard. But, it can be made to work, usually.
JMS/MN
01-14-2005 11:18:58
All three-point specs are at www.asae.org.
