WD FRONT WEIGHTS
M.C.MECHANICAL
01-11-2005 21:17:42
CAN SOMEONE TELL ME WHAT THE BOLTS LOOK LIKE THAT HOLD ONE THE ONE PIECE FRONT WHEEL WEIGHTS?
MY 'B'CAME WITH J-BOLTS THAT HOOK AROUND THEINNER PART OF THE RIM .THE BOLTS THAT CAME WITH MY WD WEGHTS LOOK LIKE 1/2" BOLTS WITH PART OF THE HEAD GROUND.DONT WANT TO MISS UP MY RIMS. -THANKS MIKE
Brad Sw Ia.
01-13-2005 19:59:24
 Re: WD FRONT WEIGHTS in reply to M.C.MECHANICAL , 01-11-2005 21:17:42
Mike, it sounds like you already have the correct bolts. The original bolts had about 'half' the head ground off, you're lucky to have them. Brad Sw Ia.
M.C.MECHANICAL
01-15-2005 18:47:06
 Re: WD FRONT WEIGHTS in reply to Brad Sw Ia., 01-13-2005 19:59:24
THANKS FOR THE INFO. Brad Sw Ia.THE ONLY PROBLEM NOW IS THE BOLTS ARE SO RUSTED THEY ARE UNUSABLE.
BUT CAN BE EASY DUPLICATED . THANKS , MIKE
