Front main seal
Reggie
01-10-2005 18:54:03
Wanting to replace front main seal on Model C but having trouble removing pulley. Set screw is removed. Any suggestions?
jayw
01-12-2005 15:17:23
 Re: Front main seal in reply to Reggie, 01-10-2005 18:54:03
I have taken them off with a porter power it is a small hyp press with attachment for wheel and bearing removal you can rent 1 for abou 20 dollars a day Good luck
topsarg
01-11-2005 04:53:57
Lots of luck..I had an experience with the same thing. Even had crankshaft out and put it in a press, with heat.. Finally ended up cutting it off there with a torch. You might get lucky and soak it with something like Kroils for a few days and try it.
