WD Hand Clutch Popping Out
IowaJim
01-10-2005 08:24:25
I was out hauling hay with my 1950 WD yesterday and the hand clutch would not stay engaged on is own. It would stay engaged for about 15 to 20 seconds then pop out. What am I looking at to fix this?
Jim
Tom in Michigan
01-11-2005 10:58:09
 Re: WD Hand Clutch Popping Out in reply to IowaJim, 01-10-2005 08:24:25
Jim - Removing shims as suggested by a previous post may fix the problem. If not, remove the battery box and the clutch access cover. There are three rollers on the clutch and the surface they roll on becomes worn. Locate the large snap ring and remove/release it. Then rotate the assemble about 1/2 inch. This will provide a new surface for the rollers and will increase the "snap" and hold the clutch over center. Tom
IowaJim
01-11-2005 04:50:57
Actually the clutch doesn't "pop" out it eases out and id doesn't matter if it is under a load or not. The hand clutch just moves forward slowly until it is no longer engaged.
Jim
Bushogpapa
01-10-2005 16:11:10
Does the wagon jerk on the drawbar, and cause the clutch to disengage..?? I can only think of the linkage under the torque-tube on the Rt side, that could kick the hand clutch out. I would check the adjustments down there... On my WD-45..after I put the power kit in it, I had to remove all the spacer washers from the cup that compresses the main coil spring, to tighten it up, or the clutch would disengage for no reason--other than the tractor was pulling so hard that the hitch spring was compressing and I couldn't hold the hand clutch in..!! Let us know..we will try to figure it out...!!
Ron.
Tramway Guy
01-10-2005 16:19:52
 Re: WD Hand Clutch Popping Out in reply to Bushogpapa, 01-10-2005 16:11:10
On many WD-45s and presumably some WDs there was an option 'safety release' that disengaged the hand clutch if a pulled implement struck a very solid object (such as a rock when plowing). It is possible that your tractor has that feature and that it is misadjusted or perhaps the large spring underneath the tractor may be broken or weak.
Teddy (punchie)
01-11-2005 02:50:03
 Re: WD Hand Clutch Popping Out in reply to Tramway Guy, 01-10-2005 16:19:52
HI ; have the same trouble , I take a bungy cord, tie down cord, and set it to hold ours in gear. Works ok if set just right tension is great for baling hay, disengage and let the cord tension play the clutch. Never have figtured out why this 1951 was so touchy. Been like like this for years. ???? Teddy
jjmcdon
01-11-2005 10:39:37
 Re: WD Hand Clutch Popping Out in reply to Teddy (punchie), 01-11-2005 02:50:03
yes me wd45 diesel 1955 does the same sxact thing I am going to take shims out from the tranny clutch like the manual I have says to commensate for wear there are three shims and by reducing the number of shims i guess it grabs more and hopefully wont pope out anymore.
