Rear Blade Sway on D14
Terry Neudorf
01-10-2005 07:31:58
I've been using a rear blade to clear snow. When I angle the blade to windrow it creeps to the side. I've searched this message board for solutions to this problem but haven't really found what I'm looking for.
What's an easy way to prevent the blade from swaying on the 3 pt. hitch (it's the original snap coupler style). I was thinking of somehow running a couple of chains to the rear axle as I can't really see where else to fasten to.
Thanks
Terry Neudorf
01-11-2005 11:53:13
 Re: Rear Blade Sway on D14 in reply to Terry Neudorf, 01-10-2005 07:31:58
I see the confusion, the picture is not the type of rear blade I'm using, mine is quite a bit newer and not an Allis part.
I can probably live with the sway as long I don't put undue strain on the lift arms.
Thanks again
steve(ill)
01-11-2005 16:05:28
 Re: Rear Blade Sway on D14 in reply to Terry Neudorf, 01-11-2005 11:53:13
terry, you were on the right track. a diagonal brace from one side front to the other side rear of the 3 point arm will build a triangle section and will not sway. you could use two chains from corner to corner and form an X also. try it, it works. this is for a regular 3 point hitch, not the ALLIS hitch.
Eldon (WA)
01-11-2005 12:39:56
If this is the type of 3pt conversion that you have, it should have a rod that goes thru the drawbar mounting brackets (under the differential). There are chains that go from it to the lift arms. Sorry it is kinda hard to see them in this pic.
Terry Neudorf
01-12-2005 07:21:05
 Re: Rear Blade Sway on D14 in reply to Eldon (WA), 01-11-2005 12:39:56
Eldon
I have those chains but the rod and chains look so light duty I didn't think they would help much when snow is piled up at one end of my rear blade. At present the chains are hanging slack, I would have to move them up a few links to make them work, maybe I'll give that a try.
Thanks
Terry Neudorf
01-11-2005 06:51:46
Thanks for the info, a picture would sure help.
Ok I have to run a bar from the 3 pt attachment point on the blade to the opposite lift arm, and then where these two bars cross I insert a pin, correct?
Could I use two chains in a pinch?
Eldon (WA)
01-11-2005 08:52:09
 Re: Rear Blade Sway on D14 in reply to Terry Neudorf, 01-11-2005 06:51:46
Lets see if this pic works....otherwise look in the "implements" section on the left - where I loaded the pic.
try again
01-11-2005 08:53:35
 Re: Rear Blade Sway on D14 in reply to Eldon (WA), 01-11-2005 08:52:09
Eldon (WA)
01-10-2005 18:52:57
Terry it sounds like you are missing some parts on the blade. The arms that attach to the lift arm latches on the tractor should form a box with 2 diagonal straps. A pin holds these straps forming 2 triangles which eliminate the sway. Usually you have to pull the pin when hooking up the blade in order to attach the lift arms. Then you raise the blade and center it in order to get the pin back in.
steve(ill)
01-10-2005 19:52:52
 Re: Rear Blade Sway on D14 in reply to Eldon (WA), 01-10-2005 18:52:57
like Eldon said youare missing the diagonals. you might be able to do this with one steel adjustable bar (link). basically you are trying to go from the left side of the blade where the 3 point ataches, to the right side of the tractor where the other 3 point arm attaches ( or vice versa). the side brace keeps the blade from swinging side to side. i acutally have a 1/2 inch by 2 inch bar with two pins i install. it is non adjustable, but functional.
