WD45 PTO Drive Gear Value
Tramway Guy
01-09-2005 06:45:44
What is the flanged drive gear worth on used market? And is it available through AGCO? This is the one that bolts to the hand clutch pack. I need one and I have a located one but no idea if it is worth what they"re asking.
BushogPapa
01-10-2005 16:19:22
 Re: WD45 PTO Drive Gear Value in reply to Tramway Guy, 01-09-2005 06:45:44
If you have to remove those gears--and certainly if you buy any used gears for the WD-45 PTO..Have Them Magnafluxed to be SURE they are Perfect...!!! Have the lower gear box Magnafluxed also...especially at the area where the shaft goes thru the "ears"..they can fail there.. These WD-45 are Powerful Rips, and can be damaged by an inexperienced operator in no time.!! The PTO can be torn out easily, if you don't engage the gearshift, Before you engage the PTO...!! You probably know that, but I am sure some won't know it..!!
BM
01-09-2005 07:32:52
We sell ours for 75.00 We call it the intermediate gear, but it's the same thing as what you're talking about.
Tramway Guy
01-09-2005 18:00:53
 Re: WD45 PTO Drive Gear Value in reply to BM, 01-09-2005 07:32:52
I thought the intermediate gear was the one just below, with two different size gears on it.
I presume that $75 is for a used one??
norm steinman
01-10-2005 18:29:04
 Re: WD45 PTO Drive Gear Value in reply to Tramway Guy, 01-09-2005 18:00:53
we have the upper gear with the 4 bolt holes for the clutch--1-574-342-4545-days--are available from agco I think couple yrs. ago pricey
Teddy (punchie)
01-11-2005 03:04:00
 Re: WD45 PTO Drive Gear Value in reply to norm steinman, 01-10-2005 18:29:04
Start at bottom and go up. PTO gear box only I would say around 50.00 . Gears and box 75.00 - 100.00 . Gears up in tractor thinking there are two, around 50.00 each. If it is the upper one I price it around , trying to recall I think it was around 175.00- 250.00 mark(NEW). What a bear to put back together. I had to tie thread around the parts and washers to get it back in place, my failed do to the handle clutch snap ring coming off. Prices are ball park. Have a Good One !! Teddy
Tramway Guy
01-11-2005 05:44:01
 Re: WD45 PTO Drive Gear Value in reply to Teddy (punchie), 01-11-2005 03:04:00
Thanks for all your responses. I now have a pretty good idea of what I'm looking forward to and some good things to watch out for!
