Gear Oil
phil(va)
01-08-2005 19:18:31
I'm new to A-C. Mostly have Fergusons. Got a manual for my CA. It says use non foaming 20 wt. or 10 wt. oil in tranny/diff/pto, depending on outside temperatures. I'm not sure what is in there now, so I'm thinking to replace it to be sure. What I assume the manual means, in today's vernacular, is 20 wt. (or 10 wt.) non detergent motor oil. Is that correct? Or should I be using hydraulic fluid, like the 134 that some of the old Fords use? Or something else? Thanks for replies.
wdTom
01-09-2005 11:15:22
 Re: Gear Oil in reply to phil(va), 01-08-2005 19:18:31
have been using "tractor lube" in a C for years now. Doesn't get a lot of use, but has been working well. Tractor lube is a general prupose oil for most things on a tractor except the engine.
Sid
01-08-2005 21:54:37
I understand that to be correct, and that is what I use in my WD hydraulics. Some say you can use todays hydraulic fluid and some insist it is better. I have no reason to argue that point but my thought is I am using what Allis Chalmeres recomenned for my tractor and it has done well for going on fifty years so I am staying with the Non detergent in mine.
jayw
01-09-2005 05:25:08
 Re: Gear Oil in reply to Sid, 01-08-2005 21:54:37
Darn good question maybe all the old allis guys out there will give there 2 cents worth Ive never been sure just what to put in the allis CA I just recently purchased Dick and steve might know for sure. Maybe we can get alot of good input from these fellas
steve(ill)
01-10-2005 19:58:23
 Re: Gear Oil in reply to jayw, 01-09-2005 05:25:08
the tractors should now use 20wt hy-trans or a universla hydraulic transmission fluid. you can get at wal mart or farm store. this oil is non foaming, anti- water, etc. many better addatives than regular motor oil. cost about the same as motor oil.--- to answer your question , will motor oil work? yes, thats all they had 50 years ago, hy-trans is better, but motor oil wil work as long as you dont work hydraulics too hard and get it to foam up.
phil(va)
01-12-2005 16:19:47
 Re: Gear Oil in reply to steve(ill), 01-10-2005 19:58:23
Thanks to all! Steve, do you know if motor oil will mix ok with the hy-trans. What's in there now doesn't smell like motor oil, has a little sulfur smell, and seems light, like maybe 20 wt, so i'm assuming it may be hy-trans.
Herb D
01-13-2005 01:34:23
 Re: Gear Oil in reply to phil(va), 01-12-2005 16:19:47
How are the reduction gears at the rear wheels oiled? Are they separate using 90W gear oil or are they somehow connected to the tranny.
I'm asking this for a neighbor who just got a CA.
Thanks in advance.
A.Irvin
01-13-2005 15:52:02
 Re: Gear Oil in reply to Herb D, 01-13-2005 01:34:23
Herb, my CA manual says to use the same 20W non-detergent oil in the final drives that is used in the trans/hydraulic/diff. You should find a little plug on the inside of the final drive housing just under the axle housing. Fill the drive up to this plug.
steve(ill)
01-14-2005 15:56:45
 Re: Gear Oil in reply to A.Irvin, 01-13-2005 15:52:02
first of all it is not a good idea to mix oils. the transmission of a CA is not that sophisticated, but still not a good idea. hydraulic oil normally does not smell like sulfer, but an old gear lube might seem that way. trans only holds $12. worth of oil, i would change all.----- there are three 1/2 inch pipe plugs under the trans, bevel and pto boxes. drain all three and fill thru one 1 inch plug by your left foot.---- lastly, the final drives are two sheetmetal pans under the reduction gear, set insdie the rear wheel rims. you need to take the pan off, clean and reinstall. refill thru the 1/2 inch plug. use 90 wt gear lube for the final drives, and yes-- the CA manual is a miss print. should be 90 wt like the B and C tractors.
phil(va)
01-19-2005 09:51:37
 Re: Gear Oil in reply to steve(ill), 01-14-2005 15:56:45
Thanks, Steve.
