WHAT MODEL TRACTOR IS IT ????????????
trailgroomer
01-08-2005 18:10:35
I have a allis W speed patrol, Serial # 1E-2601 which makes it a 1948 according to list. What model tractor is it? It does have a curved shift lever if that helps. Thanks
bennie schweihs
01-11-2005 06:51:21
 FIAT CRAWLER FD5 in reply to trailgroomer, 01-08-2005 18:10:35
looking for 2-parts, 1-dash, 1-wiring harness.
bennie schweihs
01-11-2005 06:55:17
 Re: FIAT CRAWLER FD5 in reply to bennie schweihs, 01-11-2005 06:51:21
fiat crawler model fd5, need 1-dash, 1-wiring harness
old
01-08-2005 19:59:42
 Re: WHAT MODEL TRACTOR IS IT ???????????? in reply to trailgroomer, 01-08-2005 18:10:35
Its a speed patrol which is based on a WC/WD tractor but its in a class of its own, it really isn't a tractor but a road grader.
trailgroomer
01-09-2005 04:04:38
 Re: WHAT MODEL TRACTOR IS IT ???????????? in reply to old, 01-08-2005 19:59:42
Right, I know. But is it a WC - WD - or WD45 ? Has engine # U-3019-28.
Sid
01-09-2005 07:11:44
 Re: WHAT MODEL TRACTOR IS IT ???????????? in reply to trailgroomer, 01-09-2005 04:04:38
You might already know but according the serieal number info on this site the last WC was built in '48 the first WD was built in '48. The number you give for the engine is nothing like the serial numbers that I have seen on a WD engine.
Aaron SEIA
01-09-2005 14:15:15
 Re: WHAT MODEL TRACTOR IS IT ???????????? in reply to Sid, 01-09-2005 07:11:44
He wasn't giving serial numbers, he's using the casting numbers found on the block. The engine serial number is located on a flat spot in the block just behind the carb.
Aaron SEIA
trailgroomer
01-10-2005 14:33:13
 Re: WHAT MODEL TRACTOR IS IT ???????????? in reply to Aaron SEIA, 01-09-2005 14:15:15
I found the right numbers. It is W143210G. Also there is a tag screwed to engine block just in front of carb, 11-29-44. Can you help me now. Thank you
Aaron SEIA
01-09-2005 06:31:33
If it's a 48, it has to be a WD engine. Not that it matters too much, the WC and WD were basically the same engine. All the parts for a WD will fit (and have probably already replaced) all the WC parts if it were a WC engine.
Aaron SEIA
