wd new sleeves
robbin
01-08-2005 05:44:53
can you put d-17 sleeve kit 4 1/8 bore in a WD?
Is the only difference the new pistons would be
7.5 to 1 instead of 5.5 to 1?
knauffj
01-08-2005 09:44:31
 Re: wd new sleeves in reply to robbin, 01-08-2005 05:44:53
According to our Agco parts dealer, the high compression kit for a WD45 is the same kit/part number for the D-17 (It's not an Agco part. A&I??). That's the way I went for my WD45. It may or may not work for a WD. Isn't the stroke only 4" in a WD. WD45 is 4.5" Good luck with your project!
JMS/MN
01-08-2005 16:54:18
 Re: wd new sleeves in reply to knauffj, 01-08-2005 09:44:31
I think the difference in stroke between the WD and WD45 is the difference in the crank- the 45 crank has a different throw dimension. That changes the compression. ie- the piston moves farther because the throw on the 45 crank is longer.
Jim se Il
01-08-2005 18:03:44
 Re: wd new sleeves in reply to JMS/MN, 01-08-2005 16:54:18
WDs WD-45s use same rods diff cranks 4 stroke on wd 4.5 on 45s so wrist pin to piston crown is diffrent height 45 pistons in wd with 4in stroke would lower compression would be lucky to run. wd pistons with 45 crank would raise compression not sure you could put head on pistons sticking out of bore
