WD 45 Transmission (3rd gear)
Toby
01-06-2005 16:31:14
I have a 1954 WD 45 Gas. When I put the transmission into third gear it does not seem to go in all the way and will pop out when I let the clutch out, could it be because the shifter is worn out, and if so how do I fix it, or could it be a worn out gear.
Thanks Toby
Fredd
01-08-2005 07:01:08
 Re: WD 45 Transmission (3rd gear) in reply to Toby, 01-06-2005 16:31:14
I have a WD 45 and the same problem occurs when the clutch is let out roughly or the tractor is holding the load back going down a hill. The problem is a worn out shifter but a solution I have not obtained.
A.Irvin
01-06-2005 18:16:52
Seems AC had problems with 3rd gear in several different models. My 55"CA had the same problem. If your WD45 third gear shares the shifter fork with second gear, see if second doesn"t engage fully. That was the problem with mine, swapped out the shifter mechanism and solved the problem. Otherwise, the collar or gear is fried. I have been told that third gear on a CA is cut different than the others which leads to this problem. Maybe it"s the same for your WD45?
