Traction booster/position control
jrlii
01-05-2005 14:28:08
I've read my 170's manual section on the traction booster & position control mechanism about ten times and I just don't get it.
While pulling a three point bush hog it either slowly sinks 'till it drags or slowly rises 'till it isn't cutting and has to be lowered again.
I usually lower it 'till it looks about level with the tail wheel and leave the lever in the position it pops back into. I understand that if I pull it back past the detent it should lock in position.
I have the impression that the position control will give the bush hog some give when crossing the botom of a dip, something I have lots of!
Should the traction boost lever be:
1. Next to the position control lever?
2. All the way forward?
3. All the way back?
TIA!
Fredd
01-08-2005 07:33:51
 Re: Traction booster/position control in reply to jrlii, 01-05-2005 14:28:08
The Traction booster was an invention that was meant to do just that boos traction. The mechanism works when the tractor is pulling hard and you are usin a tillage impliment (a plow). It raises the arms to pull down on the rear wheels of the tractor to add more traction. You have mis-interpreted the use of the traction booster. The brush hog should not make it function.
JMS/MN
01-06-2005 07:43:42
The traction boost is used on mounted tillage equipment. It should be off when using your bush hog. I'm not familiar with the control on the 170, but on a D17, that would be in the lower position.
Sid
01-05-2005 18:12:03
To be honest I have never used the traction booster on my 170 and it has been awhile since I have read the manual. I suggest you try lowering the three point all the way, then raise the three point with the position lever until it is where you want it to be. You should then be able to raise the lift arm all the way up and when you let it back down it should go no farther than that position. I do not think the traction booster would make any difference. I do not think the position control has any allowance for up and down when crossing dips. Some around here use a chain in place of the third arm to allow for this.
Robert Jones
01-06-2005 19:30:18
 Re: Traction booster/position control in reply to Sid, 01-05-2005 18:12:03
Im not familiar with your tractor but on my ca you can lockout the traction boost with a screw on the side of the pump housing I would think you would be able to also. The traction boost should only raise the implement some as it is intended to raise up on a plow to place more weight on the rear wheels in tough spots while plowing. But I guess a bush hog bouncing around in back could make it raise and lower it.
