Are parts available?
Sloppy shifter-
01-05-2005 13:42:51
The plastic collar, 'washer', snap ring, and or a new/rebuilt shifter rod. Are any of these still stocked/available? I've sifted through over 700 previous posts on shifter probs and haven't found a good parts source. Any ideas are appreciated!
Thanks, and email for bra
01-06-2005 07:16:44
 Re: Are parts available? in reply to Sloppy shifter-wd45, 01-05-2005 13:42:51
The 'collar' that fits beneath the retainer on top of the gearshift ball appears to be plastic on mine, it could be a 'make-do' replacement. Email is linked. Thanks again to both!
Brad Sw Ia.
01-07-2005 11:11:58
 Re: Are parts available? in reply to Thanks, and email for bra, 01-06-2005 07:16:44
I believe most of the parts are available. Drop me an e-mail if you are interested.
Thanks, Brad!
01-07-2005 19:37:50
 Re: Are parts available? in reply to Brad Sw Ia., 01-07-2005 11:11:58
Went back and checked my book and for sure there are no plastic parts in the shifter. Looks like someone cobbled up something for a spacer. I was able to find the parts I needed. Thanks again for the offer, I may need your help in the future.
Brad Sw Ia.
01-06-2005 06:23:05
I'm not aware of any 'plastic' parts for the gear shift on a WD45. Most all the other parts are still available, I have gotten many parts for mine, pins, snap ring, bevel washers, etc. I'm not real sure about the gear shift handle itself, though. If I had your e-mail address, we might be able to help. Thanks, Brad Sw Ia.
mjamison
01-05-2005 18:34:32
I had the same problem with my 45. I called several salvage yards looking for a good shifter, and know one had any, they are a hot item. the prices they were getting for a used shifter was 70-250$. I thought was high. I ended up welding the end of my shifter and it works as good as it did before.
