c a engine swap
fredinpa
01-04-2005 09:05:06
will a 149 cu in engine fit into a c a without big time changes? thank you in advance
Dick L
01-04-2005 13:54:48
 Re: c a engine swap in reply to fredinpa , 01-04-2005 09:05:06
Yes! You will have to use the flywheel and clutch assembly from the CA. The four studs from the front of the CA engine should work fine in the 149 ci D engine. The four holes in the 149 engine are NC 5/8". If you still have a CA engine they will be the same. The B"s and C"s have NC 1/2" taped holes to mount the front end fast. What ever you have the 149 will need the NC 5/8" stepped down to NF 1/2" studs. If I remember correctly you will have a little messing around with the radiator hoses to do. I am not real sure but I think the 149 has a larger hose.
I started to put one in my C but changed my mind because of the pulling rules. I think the feller I sold the block to did put it into a C. He used to post here, if he checks in he might join in with the total skinny.
