WD fluid refill
fonecop1
01-03-2005 16:33:37
the info I have says that the clutch, transmission, and differential holds 17 quarts and should be filled level with the 2 filler plugs for all three. it also says the final drives take 1 3/4 quarts each but it doesn't say if there is a seperate filler for final drives. I suspect that you just use the 2 filler plugs to get fluid to everything but wasn't sure since they listed the final drives seperate. does anybody know?
Billy johnson
01-04-2005 16:49:06
 Re: WD fluid refill in reply to fonecop1, 01-03-2005 16:33:37
Sid is correct the two pans are the final drive covers, follow sid's instructions.
Sid
01-03-2005 19:25:41
What I understand, they are refering to the pans inside the wheels that hold about 1 3/4 gear oil. This pan must be removed to get the oild oil out. they have a filler plug on the inside toward the drawbar. Hope this is what you are referring to.
fonecop1
01-04-2005 19:16:38
 Re: WD fluid refill in reply to Sid, 01-03-2005 19:25:41
Thanks Guys. I found an interesting thing on another board about this. a guy posted a picture of a mod he did on his by putting in drain plugs in each pan so he wouldn't have to remove them to change the fluid.
