WD-45 Sediment Bowl
Martin Miller
01-02-2005 18:16:31
The sediment bowl on my WD-45 is leaking. I put my screen on the bowl, fits right in and then I put the cork gasket on top of it set it in and tighten it up. Is this the correct way of doing it? Do I need to buy a new gasket? Any help would be appreciated.
Sid
01-02-2005 18:50:51
 Re: WD-45 Sediment Bowl in reply to Martin Miller, 01-02-2005 18:16:31
Yes that is right way of doing it.You more than likely need a new gasket but, you might check where the top side of the gasket goes to see if it is clean. I had one that would not stop leaking and it had part of the old gasket stuck in there. Another possibility would be that the bail is sprung and will not tighten. Also any chips in the rim of the bowl itself.
Jerry Coulter
01-03-2005 08:07:05
 Re: WD-45 Sediment Bowl in reply to Sid, 01-02-2005 18:50:51
Another common problem results from people using pliers to tighten the bowl instead of their fingers. That will warp the gasket seat and requires replacing the assembly.
