Allis 7000,Oil problem
Randy Hunzeker
01-01-2005 14:25:32
Hi there,can you ac guys help me,I have a 1976 allis 7000,and in the mornings after you start the tractor you have to bleed the hyd pump so it will steer,also,now it is shooting oil out,where the shifter goes in,any ideas,how serious???thanks for any info,Randy
gcasper
01-03-2005 20:03:50
 Re: Allis 7000,Oil problem in reply to Randy Hunzeker, 01-01-2005 14:25:32
You may have two problems here. The transmission has a separate resovoir and the rear axle housing has its own on the 7000 models. These are two different levels as well. They had a problem of a seal going out in transmission and the oil getting together which would cause your oil level to be too high in one compartment and low in the other . Are both trans and rear axle oil levels where they should be? Do you have to add hyd oil? Hyd pump may be starving for oil or is getting worn so loses prime.
