Need help with serial number
Jim's57WD45(TX)
01-01-2005 09:20:12
I have a 1950's A/C with engine serial number: WD323576PA. The engine has abolt on side cover on the governor/distibutor side. Can anyone help identify the engine model and year?
Thanks
ACEd
01-03-2005 12:06:14
 Re: Need help with serial number in reply to Jim's57WD45(TX), 01-01-2005 09:20:12
Hey guys - I think I am Brian's source on motor vs tractor s/n. I had complied a list based on some research I did both on WC/WD/45 and on B/C/CA. Where ever possible I get a set of tractor and motor s/n and try to match them up to the data base - but the Nebraska test tractors were out of sequence and some of the K motors make for conflicts - anyway, if you give me the tractor numbers and motor numbers I would be happy to update my data base. Best. Ed
Sid
01-01-2005 10:03:00
It is a WD according to my tractor manual the PA at the end indicates it is a high compression designed to burn 60 octane or hihger gasoline. My WD was built in 1951 and it"s engine number is WD347987PA. I have been told that it is the original engine. If you have the tractor number go to the research section on the left and look up that serial nember for the year the tractor was built.
Jim's57WD45(TX)
01-01-2005 10:17:42
 Re: Need help with serial number in reply to Sid , 01-01-2005 10:03:00
Wher do I look for the tractor number? Is there a place on the web where I can find the engine serial numbers, such as the one you have? Thanks!
Sid
01-01-2005 22:00:50
 Re: Need help with serial number in reply to Jim's57WD45(TX), 01-01-2005 10:17:42
The tractor number is located at the left brake cover or the left rear of the axle housing. Mine is on the back of the axle housing. I was wrong when I said it was a 51 it is a 52. My keyboard is not always right, neither am I as far as that goes. Sorry I do not know of any place to check the engine serial number.
Nathan (SD)
01-01-2005 17:24:07
According to the Brian Smith engine research the 323576 engine was likely produced in 1952 and the 347987 engine was probably made in 1953. There is no foolproof way to tell when the engine was built but he has used serial no.s from tractors that had engine no.s recorded when they were new and made an eqation to aproximate the year of manufacture for the engine. He has been on the button with the two tractors I have checked that I knew were original.
