wd hydualic pump knocks when lifting loader
cj bastin
01-01-2005 05:02:16
i have a question on wd hyd pump i am looking at a tractor to buy all looks good except hyd pump makes knocking sound when it lifting loader loader happens to to have low pressure cylinders on it wondering if this would have anything to do with it or something more serious thanks
Aaron SEIA
01-01-2005 06:30:56
 Re: wd hydualic pump knocks when lifting loader in reply to cj bastin, 01-01-2005 05:02:16
My pump rattles when it's lifting equipment too. I think it's just the nature of the piston design. The only time low pressure cylinders are a problem is if you take them to max stroke, probably something you can't do on a long stroke loader cylinder. I'd be more concerned about how far up you can get the cylinders on the standard oil capacity of the hyd reservoir.
Aaron SEIA
