Wd45...are there more than one gas motor?
RaymondT
12-31-2004 19:38:09
I"ve been looking at over haul kits for wd45"s and see two different kits... one for a G226 and one for a 226 cid . I think these #"s are what i seen. How do i find out the motor i have? thanks
dan wc ne wyo
01-01-2005 18:14:29
 Re: Wd45...are there more than one gas motor? in reply to RaymondT , 12-31-2004 19:38:09
Hi Raymond, I think if you check with an AGCO dealer the main brgs on a G226 are the same as a D17 and they are a larger diameter, also the thrust surface is in the center main instead of the end as on the 201 and 226 uses in WC, WD, and WD45 tractors. The rod bearings and cyl. kits can be used in G226 ,WD45, and D17 engs. Also G and W prefix indicates power unit engs. WC, WD, and 45 is tractor prefix. Using these pistons in WC andWD engs. should include the 4.5 stroke crank from WD45 to maintain correct compression. HTH dan wc ne wyo.
RaymondT
01-02-2005 08:58:47
 Re: Wd45...are there more than one gas motor? in reply to dan wc ne wyo, 01-01-2005 18:14:29
Thanks for the help Dan & Aaron. This is a great site.
Aaron SEIA
01-01-2005 06:26:30
There was only one motor for the WD45, a 226 cubic inch 4" bore, 4.5" stroke. Might have been some different compression ratios, but only the one engine size.
Aaron SEIA
