Undersized Cam Bearings For B
Don TN
12-31-2004 17:20:57
On my 39 B, the cam journals all measure 1.746. The specs for the bearings are from 1.752 to 1.753. This will leave a clearance of from 0.006 to 0.007. The spec clearance is 0.002 to 0.004. I have not been able to locate any undersized cam bearings. Where would I find them? Should I even be concerned about the larger clearance? My fear is that this would cause lower oil flow to the main bearings. If undersized bearings are not available, are there any economical options other than a new cam? Thanks for any help.
Lee in MI
01-02-2005 16:12:49
 Re: Undersized Cam Bearings For B in reply to Don TN, 12-31-2004 17:20:57
When I worked at Fuller transmission some of the shafts would get ground under size, they sent them out to a place to get chrome plating on the surface that was undersize and then have them back in the production line to get reground.
