WD exhaust manifold gaskets
Hoz
12-31-2004 13:32:52
I have always had a problem of the exhaust manifold gaskets lasting. The factory replacements (metal with fiber gasket) seem to burn out in a short time. Any ideas on how to get them to last longer?
BushogPapa
12-31-2004 16:05:17
 Re: WD exhaust manifold gaskets in reply to Hoz, 12-31-2004 13:32:52
When I change manifold gaskets..and it is really seldom, I rub High-Temp (Orange) Gasket Sealer into the asbestos rings... I think it holds the asbestos together, and--it helps by sticking the gaskets and metal cups all on the manifold while I slide it back on...!! You need to get all the manifold studs, or bolts pretty near the same torque, to get the manifold to hold Flat against the head... I would re-tighten them, after the engine gets good and warm, too... Ron...
bryan g in mo
12-31-2004 13:47:28
put a straight edge across the manifold ports, and make sure the manifold is not warped
Jim se Il
12-31-2004 22:20:48
 Re: WD exhaust manifold gaskets in reply to bryan g in mo, 12-31-2004 13:47:28
you will also want to check the head with strait edge across ports if it has been run with leaking gaskets very much it can burn out around ports and the only way to fix that is pull head and take to machine shop and have surfaced also can have manifold surfaced
