Allis B or C
Russ Snyder
12-30-2004 16:43:10
Are B and C Allis' the same except for the front end? Were any C's made with wide a wide front end?
Thanks
Eldon (WA)
12-30-2004 17:27:02
 Re: Allis B or C in reply to Russ Snyder, 12-30-2004 16:43:10
The B has a different steering arrangement (front radiator shroud will be different) and the rear end is narrower than a C. It can have an adjustable wide front as well as the arched.....adjustable will usually have the dished rear wheels like the C. The C is available in tricycle front (2 wheels), single front and adjustable wide front. Most C's out this way are wide front.
steve(ill)
12-30-2004 19:28:46
 Re: Allis B or C in reply to Eldon (WA), 12-30-2004 17:27:02
they have the same radiator, hood, motor, transmission, clutch, gas tank, bevel gear-pto box, and hydraulic pump. the B has 12 inch narrower rear axle tip to axle tip, internal axle parts are not interchangable. ALL B are wide front end, SOME C are wide, quite a few are narrow.
