wd45 water in exhaust
possum
12-30-2004 15:17:03
I have 55 wd45 I recently replaced gaskets on and since then wen it runs it blows lots of water out the exhaust. any suggestions?
BushogPapa
12-30-2004 21:00:35
 Re: wd45 water in exhaust in reply to possum, 12-30-2004 15:17:03
Have you re-torqued the head..?? I know, it is a pain to do but you should do it with the engine WELL heated, to get the torque rite... I always have trouble with that plate between the two rear head bolts that covers a rear water opening... I often thought a water outlet from a WC would be a better idea..it would use both water outlets...!!
Guyzoo
12-30-2004 16:00:34
sounds like the head gasket is seeping
you probably have anti-freeze getting on the pistons
