loading tires
OntPete
12-30-2004 12:30:14
Hi, on a recent mild day following a cold snap I noticed that one rear tire is @ 1/2 full while the other is mt. I would like to fill the one & add to the other. The tractor is a 50 WD and has 13.6 X 28 tires. What I would like to know is what ratio is used to mix the calcium with water (I am assuming that flake calcium can be used) and what volume is required in a tire of this size thanks Peter
Phill Snartland
01-03-2005 14:15:36
 Re: loading tires in reply to OntPete, 12-30-2004 12:30:14
You might also want to look at a non-chloride tire weighting solution. One of these products is called Rimguard (www.rimguard.us). Claims higher density (more weight per volume) and won't corrode your rims. I'll be using this in the spring when I finish my WD-045 restoration. Good luck!
Dick L
12-30-2004 12:40:20
This sit should give you all the information you need. Just go to the bottom of the page and I think the second from the left will help.
