HYDRAULIC SYSTEM ALLIS CHALMERS C
ROBERT KRUEGER
06-18-1999 07:56:53
DOES THE TRANSMISSION AND THE PTO GEAR BOX AND HYDRAULIC PUMP ALL SHARE THE SAME FLUID? ALSO IS THIS FLUID 20 WEIGHT HYDRAULIC OIL?
Ed Kiburis
06-18-1999 12:30:35
 Re: HYDRAULIC SYSTEM ALLIS CHALMERS C in reply to ROBERT KRUEGER, 06-18-1999 07:56:53
The manual specification for the oil in the Transmision/hydraulic pump and the engine is 20 weight. The transmision/hydraulic pump should be non-detergent to prevent foaming in the hydraulic system. I've been using 20 non-detergent in the rear and sometime 30 in the engine. I have only found one store that carries 20 weight.
ED
06-18-1999 13:09:59
 Re: Re: HYDRAULIC SYSTEM ALLIS CHALMERS C in reply to Ed Kiburis, 06-18-1999 12:30:35
ED
THANKS FOR THE INFORMATION. THE REPAIR MANUAL THAT I HAVE HAS VERY LIMITED INFORMATION IN IT. I NEED TO GET A MORE DETAILED ONE AND ALSO AN OWNERS MANUAL WOULD BE VERY USEFUL. THANKS AGAIN. BOB
harlow
06-18-1999 10:16:56
Robert,
The transmission and the PTO do share fluid. I have not yet found written info to tell you what type of fluid to use. I have been using 20 weight oil and have had no problems. I have used the tractor to rake alot of hay and it seems to like it.
Good Luck
HARLOW
06-18-1999 11:49:31
 Re: Re: HYDRAULIC SYSTEM ALLIS CHALMERS C in reply to harlow, 06-18-1999 10:16:56
HARLOW
THANKS ALOT FOR THE TIP. I JUST COULD NOT FIND ANY PLACE TO ADD FLUID TO THE PTO GEAR BOX. BOB
Harlow
06-21-1999 13:10:53
 Re: Re: Re: HYDRAULIC SYSTEM ALLIS CHALMERS C in reply to HARLOW, 06-18-1999 11:49:31
Bob,
On the clutch side of the tractor in about the middle of the differential is a plug. You add fluid there.
Harlow
ROBERT KRUEGER
06-21-1999 13:37:00
 Re: Re: Re: Re: HYDRAULIC SYSTEM ALLIS CHALMERS C in reply to Harlow, 06-21-1999 13:10:53
THANKS FOR THE INFO ON THE PLUG-IT HELPS MUCH!
