allis chalmers WD
robbin
12-29-2004 16:54:36
WHAT IS ACCEPTABLE COMPRESSION IN CYLINDER FOR
GASOLINE ENGINE
Kevin (FL)
12-30-2004 07:20:04
 Re: allis chalmers WD in reply to robbin, 12-29-2004 16:54:36
WD had fairly low compression ratio (5.75:1), so you might see pressures in the 70-85 PSI range, depending on engine condition. Higher readings are possible with carbon buildup, etc. Main thing is that the four cylinders are fairly close on the readings.
wilko
12-29-2004 21:00:34
I'm sure someone will follow with the correct factory specs, but as a preliminary I'll say that relative uniformity between the cylinders is a big factor. If you have between 90 and 110 lbs in each cylinder in an old tractor engine, you're probably not in too bad a shape.
