B hydraulics
genep
12-29-2004 12:52:10
I have a friend who has a "B" he got from his relatives. From the serial number listings it is a '49 model. It has a hydraulic control valve on the PTO housing and the 3 point will raise but not lower. We've moved the lever on the valve to it's full travel but still no lower, even with weight on it. Any suggestions on what to look for or check first will be much appreciated. My email is open.
Gene
Greg B.in Mi
12-30-2004 15:26:57
 Re: B hydraulics in reply to genep, 12-29-2004 12:52:10
I would start by checking for a blockage either in the line or the valve itself, be careful taking off the line as it may be under pressure. Also make sure the handle on the valve is not slipping, there should be a screw of some kind to tighten the handle to the valve. the whole system is pretty simple just be sure to keep work area clean as not to introduce dirt into the hyd. system or you will start a whole new host of problems. good luck let me know if this works.
