Diagram for 1947 Allis Chalmers B
KBM
12-29-2004 08:00:54
I am looking for a diagram of a 1947 Allis Chalmers B to repair something on it. Is there any diagrams that are free to view online?
Dick L
12-29-2004 08:41:31
 Re: Diagram for 1947 Allis Chalmers B in reply to KBM, 12-29-2004 08:00:54
Not knowing what you want to repair and I don"t know of a drawing that covers the complete tractor in only one drawing, feel free to look thru the drawings on my site and see if you can find something that will work.
KBM
12-29-2004 08:53:31
 Re: Diagram for 1947 Allis Chalmers B in reply to Dick L, 12-29-2004 08:41:31
Thanks so much. I couldn"t find what we are looking for. We need a diagram that shows the head where the lifters are. We got water in the oil.
Dick L
12-29-2004 09:07:22
 Re: Diagram for 1947 Allis Chalmers B in reply to KBM, 12-29-2004 08:53:31
Terminology gap here. The lifters would be in the block. Push rods set in the lifters/tappets and move the rocker arms to open the valves.
With water in the oil, other than a blown head gasket, you would be looking at the water chamber plugs or commonly known as freeze plugs under the rocker arms. They sometimes rust thru and seep water out into the oil. To check that just remove the valve cover, clean the tops of the freeze plugs, fill the radiator with liquid and add a little air pressure to the radiator and if they are rusted thru, you will see liquid appear. Quick and easy check. If they are bad, NAPA should have them in stock.
KBM
12-29-2004 09:13:10
 Re: Diagram for 1947 Allis Chalmers B in reply to Dick L, 12-29-2004 09:07:22
Is there anyway I can send you a picture of what I think is the problem, so I know we are talking about the same thing. I really do appreciate your help! [email protected]
Dick L
12-29-2004 09:50:05
 Re: Diagram for 1947 Allis Chalmers B in reply to KBM, 12-29-2004 09:13:10
The email address should work now. Shoot the picture my way.
Dick L I DIDN'T MEAN
12-29-2004 09:11:04
That it was the only place water would get into the oil. That is where you were asking about but a lot of the time water gets in around the bottom of the sleeves.
KBM
12-29-2004 09:28:49
 Re: Diagram for 1947 Allis Chalmers B in reply to Dick L I DIDN'T MEAN, 12-29-2004 09:11:04
It is gas not diesel, if that makes a difference. Also please note I sent another comment at the same time you added one, so please read it.
Dick L That Is Your Probl
12-29-2004 12:19:16
 Re: Diagram for 1947 Allis Chalmers B in reply to KBM, 12-29-2004 09:28:49
That little hole is not supposed to be there. Take a big screwdriver and poke it thru the plug, pry it out. Take the old one to NAPA and they should be able to sell you a new one. Good advise would be to replace all of them while you are at it. Nice clean engine. When I get a chanch I will post the pictures for others to see your problem.
KBM
12-29-2004 14:03:52
 Re: Diagram for 1947 Allis Chalmers B in reply to Dick L That Is Your Probl, 12-29-2004 12:19:16
You hit it right on the nail! Thanks so much! We were selling it at an internet auction and this happened 2 days before it ends! The part was only 42 cents! We went ahead replaced them all like you suggested though. Thanks and God bless you!
Dick L PICTURES OF PROBLE
12-29-2004 12:34:57
third party image
third party image
