main bearing seals
Jim P
12-28-2004 16:32:34
I need to replace front and rear main bearing seals in the motor.In a Allis Chalmers wd45 any help would be appreciated. I have never done this before. Thanks
wdTom
12-28-2004 18:32:20
 Re: main bearing seals in reply to Jim P, 12-28-2004 16:32:34
You will need to pullthe engine. The rear seal is in the bearing cap and a bolt on seal "holder" bolted to the block above the bearing cap. Need to remove the pan and flywheel, which means pulling the engien, then it is easy. Front can be done with pully removed after engine is out. An engine stand is nice for rear seal but you can do it with the engine hanging on on it's side. Upside down is better.
