WD Fluids
Ray E Dean
12-27-2004 17:33:20
What fluid is supposed to be in the transmision and differental of a WD. And where do you fill the differental? I drained both and the look like a mix of auto trans fluid and water.
Thanks Ray
gcasper
12-27-2004 20:16:25
 Re: WD Fluids in reply to Ray E Dean, 12-27-2004 17:33:20
The fluid should be 80w -90w or 85w -140w gear lube . There is a large pipe plug on the side of the transmissin on left hand side between trans housing and side rail frame just ahead of the clutch pedal. You fill the trans and diff housing through that pipe plug. Don't forget to check the final drives as they are filled individually on each side and probably have moisture in them as well. later Gary
wdTom
12-28-2004 18:38:09
 Re: WD Fluids in reply to gcasper, 12-27-2004 20:16:25
You are correct in that the fill is on the left, but there are two, and there are 3 drain plugs too, to drain it completly you need to drain all 3, PTO, trans., and differential. Using both fill plugs, ( on the left side between the rear axle and hydraulic fill) will make it faster, you don't need to wait for the fluid to run through bearings to get to the part of the transmission that that fill doesn't really fill.
