AC rollover plows
Sheila Cole
12-22-2004 04:34:35
Recently purchased a WD 45 with roll over plows. Looking for information or manual for the plows.
Brad Sw Ia.
12-28-2004 13:15:42
 Re: AC rollover plows in reply to Sheila Cole, 12-22-2004 04:34:35
I have a plow manual, if you're interested. Drop me a e-mail. WDTom has my address, Thanks, Brad Sw Ia.
Bill(Wis)
12-24-2004 09:57:24
wdTom mentioned having your hand on the clutch all the time to stop the tractor real quick. There is a clutch throwout device that most farmers around us had. (no shortage of hidden rocks!)It drives the hand clutch forward as soon as any stoppage occurs. Stops the tractor much faster than human can react. I recommend you get one. J Danforth of OK tractors might be able to help. If not I think I can find one.
wilko
12-22-2004 20:57:46
wdTom had a lot of good advice, but I would add that it's important to back way off the throttle when you make the turn at the end of the field. Full-throttle spin turns, especially with the weight of a rollover plow, are hard on rear ends, lift arms and everything else. Throttle down as you lift the plow, then back up as the plow drops into the ground. I've seen three bottom rollovers, but never behind anything smaller than a one ninety.
wdTom
12-22-2004 18:21:03
I pulled one of those with a WD-45 for many hours as a kid. Quite a few years ago, but as I spent so much time with one I can tell you a few things. I think there are two grease fittings where the plows rotate on the main shaft. If you live where there are rocks you will break shear bolts. These bolts hold the individule plow bottoms to the main frame. One is 5/8" and the other, main one that holds upper and lower plow "struts" to the main frame is 3/4". Mostly you will shear the 5/8 " bolt and be going in a few minuts after replacing it. Once in a while after a lot of use the 3/4" will go. Getting it out can be a bear as it probably will be partly sheared in other places making the bolt sort of offset in various places, difficult to pound out. Have to loosen up a lot of other bolts. Best to use a grade 5 in this postiton, and a grade 2 on the 5/8 position, that way you will likely be replacing only the 5/8" bolt. To use, plow along until you are right at the end of the row. Raise the plow, rotate it, turn the wheel all the way in the direction of the next furrow, apply the brake to lock the inside wheel, turn the tractor, back up lining up for the next furrow, drop plow and go. Takes only seconds after you have done it a time or two. If it is rocky have your hand on the hand clutch, ready to disengage instantly if you hit a large rock. It is a game,to see if you can stop the tractor before it pops the bolt. Don't ride the clutch, or have it against the throwout bearing all the time, but be close and ready. The first time you are day dreaming you will wake up fast to a SNAP, and be fixing a bolt. All in all a great working plow, and a 45 or WD will pull a two bottom like it isn't there. Don't know if they made a 3 bottom.
Billy johnson
12-22-2004 17:23:05
I had a 2 bottom rollover sc with book, new had never been put together, sold it the book was not in very good shape.
Mark in Mizzou
12-22-2004 12:43:04
Sheila, Do you have a two bottom mold board plow with snap couplers? I"ve never seen a manual for one.
What are you needing to know?
Mark Hill
Dearborn,MO
CABOB
12-22-2004 18:12:24
 Re: AC rollover plows in reply to Mark in Mizzou, 12-22-2004 12:43:04
I GOT A MANUAL FOR MY ROLLOVER PLOW ON EBAY. BOB
