HYDRALIC PUMP ON ALLIS CHALMERS C
ROBERT KRUEGER
06-17-1999 06:59:18
I WOULD LIKE TO KNOW MORE ABOUT HOW THE HYDRALIC PUMP OPERATES ON MY 1946 ALLIC CHALMERS C. DO I NEED TO ADD A RESERVOIR FOR THE HYDRALIC FLUID OR DO I ADD FLUID TO THE PTO GEAR BOX? IF I ADD IT TO THE GEAR BOX, WHERE DO I ADD IT? ANY INFORMATION WOULD BE GREATLY APPRECIATED!
William Powell
06-17-1999 12:14:26
 Re: HYDRALIC PUMP ON ALLIS CHALMERS C in reply to ROBERT KRUEGER, 06-17-1999 06:59:18
The pump operates off of the two cams on the PTO shaft. You should not need to add a reservoir for
the C if you are using it to move the one or two
rams that can be mounted. The fluid is added into
the gear box. There is a large square headed plug.
WILLIAM POWELL
06-18-1999 11:53:42
 Re: Re: HYDRALIC PUMP ON ALLIS CHALMERS C in reply to William Powell, 06-17-1999 12:14:26
WILLIAM
THANKS MUCH FOR THE TIP ON THE HYDRAULIC SYSTEM FOR MY C. I AM LEARNING A GREAT DEAL ABOUT THIS OLD TRACTOR BECAUSE OF PEOPLE LIKE YOU. BOB
