WD Questions
Mike@NY
12-19-2004 06:30:53
Hello all. I am doing some research on whether or not to get a WD (I haven't even found one yet that is avalable), and these few questions came up. First, what is the weight of these tractors (no weights or fluid in tires)? My books put it anywhere from 3300 to 4300 lbs. Second, can you shift gears using only the hand clutch? I aplogize if these questions have been asked before. Thanks for your help.
Mike@NY
Dave in Mo
12-23-2004 08:17:00
 Re: WD Questions in reply to Mike@NY, 12-19-2004 06:30:53
My WD weighs 4000# and it doesn't have fluid in the tires. About 30 HP means it's a 3 plow machine. Use the foot clutch when changing gears no matter HOW clumsy it is. And if you buy one, the whinning noise you hear in the rear end is okay. It's caused by the straight cut gears on the rears.
robbin
12-21-2004 19:10:12
I have a wd that the oil pump went out on.no major damage.already bouht another pump and a new set of 10 thousands over bearings rod and main.just need to get crank turned.would sell reasonable. located near pittsburgh international airport
Mike@NY
12-21-2004 16:29:37
Thank you all for the responses that I have gotten, the information has been great. Another example of how great these message boards are.
Mike@NY
Jonesy
12-21-2004 10:27:38
Mike
Visit the midwest this summer. You can still get a very nice WD in the $600 range. And mine runs just at 3400 pounds.
Dave in Florida
12-20-2004 11:07:56
My farm stock WD with one set of AC rear weights, a belt pully, no fluid in the standard tires, narrow front, weighs in at close to 4300 pounds for the pulls.
Dave
wdTom
12-19-2004 18:16:39
I forgot to mention weight. My WD,which isn't complete yet, weighed 3200 at a tractor pull last fall. When I put the fenders, hood, cowling, hydraulic cylinders, air and air filter, I think it will be close to 3500.
Tim in NY
12-19-2004 14:40:52
The weight would very depending on tire size,and whether it was a wide/narrow front. I have a wide front WD45 which weighs in at 3900-4000 lbs with 14.9x28 tires and no fluid in them. A narrow front would be 150-200 lbs lighter.I"ve seen many pull in the 3500 lb class stripped down.I would recommend using the foot clutch to shift gears. I have a narrow front WD I"d sell if you"re interested!
Mike@NY
12-19-2004 15:59:46
 Re: WD Questions in reply to Tim in NY, 12-19-2004 14:40:52
Tim
Sure I am interested. What kind of shape is the one you got in, where are you located, and what would be the asking price? Thanks
Mike@NY
Tim in NY
12-20-2004 18:32:11
 Re: WD Questions in reply to Mike@NY, 12-19-2004 15:59:46
I'm about 30 miles south of Albany. I have a complete, good running WD, in good overall condition, that I'd sell for $1500.
Mike@NY
12-21-2004 16:27:21
 Re: WD Questions in reply to Tim in NY, 12-20-2004 18:32:11
Tim in NY;
Well, thanks for the offer, but that is a bit more than I can afford at the moment. Doesn't sound bad. I will keep you in mind though. Thanks again.
Mike@NY
Gene
12-19-2004 11:01:39
I have 2 WDs that are used for general farm type work. They are very good tractors, plenty of power, for the money. 3-point hitches are relatively inexpensive.
The only problem I have found with the WDs is that without front end weights, they are light on the front end.
Shifting gears with the hand clutch. Can be done. I usually use the foot clutch - probably more of a habit then anything else.
Sid
12-19-2004 07:02:20
I have some Allis Literature that puts the weight of the WD45 at approximately 4450 pounds. Not exactly what you asked but as close as I can get on that one. "Can you shift gears using only the hand clutch?" Many will tell you they have been doing it for years and have no problems. I will tell you that sometimes when doing PTO work I will stop the tractor with the hand clutch and shift so I do not have to let the PTO wind down. The manual says to use the engine clutch (foot clutch) to shift gears.
wdTom
12-19-2004 12:44:39
 Re: WD Questions in reply to Sid , 12-19-2004 07:02:20
Whether or not you can shift with the hand clutch depends on how thick the oil is, and how warm it is from warm or cold weather, or warmed up from use. A thin oil on a hot day, with some hard use on it will probably be thin enoght to allow shifting. Ninety weight on a cold day starting up cold , no way.
Dave R (MN)
12-19-2004 08:36:02
Terry Dean's Data book puts the WD at 3,388 pounds. Drawbar horsepower 30.23, and 34.63 at the pto/belt. I can't shift mine with the hand clutch without grinding gears so I shift with the foot clutch, but if you can do it without grinding, I don't see what it would hurt.
