Allis Chalmers CA Transmission
E McEnroe
12-18-2004 07:17:21
I have a 1954 CA and third gear keeps jumping out. I would like input on this as well as where I can get the gears and shifting yoke to repair this? Thanks
A.Irvin
12-19-2004 06:19:54
 Re: Allis Chalmers CA Transmission in reply to E McEnroe, 12-18-2004 07:17:21
I have a '55 CA and had the same problem. Thought I was going to have to split the tractor. But on a hunch I swapped out the shifter mechanism with a parts tractor I have.(the metal plate on the side of tranny holds all the shifter stuff). Problem was solved! Don't know how long it will last though, I've been told our CA's have a problem with third gear due to the way the gear is cut.
dieseldr
12-18-2004 19:32:20
Those parts are available from AC, but when tearing it down you will likely find the teeth on the engagement collar (shift coupling) will be worn also-- this shift coupling also serves reverse gear, and it , too, is available from AC. But the shift coupling alone is around $950. The parts cost much in excess what the tractor is worth. Also be careful when purchasing parts, as there is a fine internal spline set of gears, and a coarse internal spline set of gears, and never the two shall swap. Good luck.
