wd no spark at plugs
paul shoup
12-15-2004 09:53:58
my wd won't start. I have spark at the coil but not at the plugs (new plugs). it was running a month ago and now nothing. Can someone give me an idea where to start. It was converted to a 12 volt system with alternator. Don't know if it matters.
RH
12-17-2004 19:10:07
 Re: wd no spark at plugs in reply to paul shoup, 12-15-2004 09:53:58
Yes I 4got the coil, but if u get am ford coil most of the 70ds and 80 have am resiter built in them, I have am WD45 12 v and haas am ford coil
RH
12-15-2004 16:17:10
Check ur points c if they r workinng and if they have spark. Changeing 2 am alt. should not have anyrthing 2 do with no spark
paul shoup
12-16-2004 10:26:50
 Re: wd no spark at plugs in reply to RH, 12-15-2004 16:17:10
I changed the points and rotor and low and behold. The wd started right up. thanks for the reply.
Doug in OR
12-17-2004 06:21:15
 Re: wd no spark at plugs in reply to paul shoup, 12-16-2004 10:26:50
The only thing I might add is... when you converted to 12 volts, did you change the coil to a 12 volt coil, or add a ballast resistor? If not, you'll be burning out points at a regular interval.
