oil pump
david w
12-14-2004 11:39:15
need oil pump for b-ac and oil pump for ca-allis.new if possible.or maybe you know of a supplier.thanks david
Dick L
12-14-2004 12:44:14
 Re: oil pump in reply to david w, 12-14-2004 11:39:15
Oil pumps for the B"s, C"s, and CA"s are all the same. What is wrong with yours that makes you want new ones? If they are not rusted up it does not take much to make them good as new. If they had water stand and rust up then you will need a different one anyway.
david w
12-15-2004 04:41:11
 Re: oil pump in reply to Dick L, 12-14-2004 12:44:14
thanks.the reason i need them is because neither engine has oil pump attached.both engines are new.still in crate.bought at an allis dealer sale.
Dick L
12-15-2004 05:53:36
 Re: oil pump in reply to david w, 12-15-2004 04:41:11
Good on you. I would be looking for new ones as well. Good luck!
