Allis CA Generator does it use a regulator?
Rodg1953
12-14-2004 07:30:37
I have a CA with a generator and the tractor has the three position switch, does this use a regulator, or is the switch the regulator??
From what I understand from the manuel the switch adjusts the recharge amount, is this true??
Thank You
A.Irvin
12-14-2004 15:01:01
 Re: Allis CA Generator does it use a regulator? in reply to Rodg1953, 12-14-2004 07:30:37
The three position switch does control lights and charge rate. All the way in 3 amps, no lights, second position, 3 amps with lights, all the way out, 10 amps with lights. The regulator is the little box piggy backing the generator.
steve(ill)
12-14-2004 15:32:23
 Re: Allis CA Generator does it use a regulator? in reply to A.Irvin, 12-14-2004 15:01:01
the little box on the generator is the cutout, whih is 1/3 of a normal voltage regulator, as mentioned, the light switch takes the place of the current regulator portion of a voltage regulator. the current is not "regulated" with a cutout system. the llight switch sets charge and "hi" or "low", not variable. it does this with the resistor mounted on the back which "sets" the F wire relative to ground.
