170 diesel transmission rebuild
Rodger
12-12-2004 19:22:04
I hsve the transmission partially separated from the tractor but cant get shafts to disengage. Is it necessary to go into right side of tractor by hand clutch to release the rear end? once apart can I slide main shaft out(forward) with out tearing the back end off the axle casting?
Gatz
12-13-2004 07:10:43
 Re: 170 diesel transmission rebuild in reply to Rodger, 12-12-2004 19:22:04
Rodger,
What's keeping it from coming apart is the shifting fork for the PowerDirector.
The shifting shaft and fork have to be removed before the PD clutch assembly will slide back.
It's not that difficult, but I would STRONGLY recommend getting a service manual...either AGCO's or IT's.
Once the tractor has been "split" (PD shaft & fork removed), the PD clutch assembly can be removed from the input shaft by taking out the large snap ring, 2 drive hubs and finally, a small snap ring that holds the clutch a'y to the transmission input shaft.
The input shaft can then be removed from the front of the transmission.
To remove the main shaft (with bevel gear) it will be necessary to remove the differential assembly which in turn means the whole rear end.
This will require removing the final drives, too.
This last part will take time and require a suitable overhead lift.
There are a number of gaskets that will be required b/4 re-assembly and seals should be replaced while you're in there too.
If you need more info, email. I could also send you copies of the manual pages pertaining to this procedure.
Gatz
