WD45 to D-17 comparison
John In Texas
12-12-2004 14:05:46
I have found several messages indicating that the engine in the WD45 and the engine in the D-17 are virtually the same with the only differance between them being the Main journal size. If this is true are the pistons the same in both models?
DanD.
12-12-2004 16:18:18
 Re: WD45 to D-17 comparison in reply to John In Texas, 12-12-2004 14:05:46
The pistons are the same size and can in fact interchange between the two engines. However, the D17 pistons are a little taller and give you a 7.2:1 compression ratio while the 45 is a little lower (I don't remember the exact ratio)
John In Texas
12-12-2004 20:37:55
 Re: WD45 to D-17 comparison in reply to DanD., 12-12-2004 16:18:18
Thanks for the info. It sounds like I can use a WD45 piston in my D-17. The differance in compression ratios and/or stroke is probably obtained from the offset of the crank. I was needing a piston for the D-17 and was only able to find WD45 pistons. If the rod is a different length it should not matter as I can pull the wrist pin from my existing D-17 and put the WD45 piston on it, I think? anyone know if this will or will not work?
DanD.
12-13-2004 15:18:58
 Re: WD45 to D-17 comparison in reply to John In Texas, 12-12-2004 20:37:55
The pistons between a WD45 and a D17 are diffeent. The D17's are taller from the wristpin to the top giving you a higher compression ratio. You wouldn't want one piston in the engine with a lower compression ratio. Replace all four if you have to. You'll have less power but would run fine.
John In Texas
12-15-2004 16:43:15
 Re: WD45 to D-17 comparison in reply to DanD., 12-13-2004 15:18:58
Thanks for the information. I will wait untill I get a matched piston or re-sleeve them all.
big jt
12-12-2004 22:08:25
A lot of the parts will mix and match up to and including whole engines. This goes from all but the real early WC's to the 170 gas.
Our mower tractor is a 45 with a series IV D17 engine in it. That is a drop in conversion.
However I would not recomend replacing only 1 piston. This will lead to a unbalanced engine with one cylinder either doing less or more of its share of the work. Can lead to problems with the block, head, and crank.
If you need to replace a piston replace the set. Or as they say you can pay me now or pay me later.
HTH
jt
iowa
12-12-2004 17:42:12
What does piston height have to do with compression ratio?
steve(ill)
12-12-2004 19:21:22
 Re: WD45 to D-17 comparison in reply to iowa, 12-12-2004 17:42:12
piston height refers to the height of the top of the piston relative to the center of the wrist pin. keeping the stroke the same, you can change the "height" a little taller, or put more dome on it and get piston further up in to the combustion chamber and thereby change the compression ratio of the motor. that is how you get a motor from 7:1 to 8:1 to 9:1 compression, by changing the height of the piston above the wrist pin.
One quick question
12-14-2004 17:33:45
 Re: WD45 to D-17 comparison in reply to steve(ill), 12-12-2004 19:21:22
You say the longer piston would go up into the combustion chamber a little further , giving higher compression ratio. But , it's not really compressing more air/fuel than the shorter piston. when the longer piston is in the down part of the stroke , it is also higher than the shorter piston. In other words , your still compressing the same amount of air in the stroke. Am I right or wrong?? I really don't know. That's why I question this.
Smitty in W. Mich
12-19-2004 02:24:57
 Re: WD45 to D-17 comparison in reply to One quick question, 12-14-2004 17:33:45
While you are right, the stroke remains the same, and so the amount of air being compressed is the same, but because the piston is taller from the wrist pin, that same amount of air is being compressed into a smaller combustion chamber, thus the higher compression ratio.
The compression ratio of a WD45 is 6.45 and that of a D17 is 7.25, the only difference being the height of the piston (measured from the wrist pin).
Texas Denny
12-18-2004 10:31:34
This is an algebra problem. Let A be the volume of the combustion camber (at top dead center). Let B be the volume equal to stroke times area of pistion (or bore). Compression ratio is (A+B)/A. When the piston comes up farther into the cumbustion chamber, A becomes smaller. And A+B is smaller as well. The ration of (A+B)/A however is bigger. (A 0.15" greater height will change compression ratio from 7.0:1 to 8.5:1.)If you haven't had one of these apart, the combustion chamber is a bit different than any car engine that I've seen. The Head is flat and the cumbustion chamber is in the cylinder. So you change compression by changing stroke or piston height. On most engines, the piston is flush at TDC with the block. To change compression on these, generally it is done by increasing bore, stroke or, shaving the heads.
iowa
12-12-2004 19:56:22
Thanks Steve...
